I have a 100/30 Bluesolar MPPT.24V Lifepo4 and 2x 230watt solarpanel-in series are connected.
I have set the battery preset as 7(Fir lifepo4).When the unit fixed the bulk led is shining .The voltage on battery is 26,71V .The charge current seen 100mAh in ampermeter when i check.It does not jump to absorbtion or float .is that normal?Do i have to use ve direct bluetooth or dongle for seting up battery type or using rotary on it is enough?
thx and Regards
