Could use a little help.
I have a Victron/Multiplus charger/inverter 12/3000/120 with the BMV-712 monitor and four Battleborn lifepo4 batteries installed in an RV.
The individual / company is no longer around that did the install, so asking them for help is non-existent. Originally as I remember, the unit would maintain the batteries at or near 100% while being in the on or inverter mode and plugged into shore power.
As time went by I noticed this was not happening anymore, the battery SOC was dropping to what extent I'm not sure. So, after several days of leaving it alone, I checked it again and the battery SOC dropped to 80%, I then just put it in charge mode for now.
What happened? did something change as in settings? If so, how do I correct it.
Thanks in advance for any help.
