Good Morning
Good Morning
The general rule is if it works don't upgrade. Some firmware is intended for incorporating new products into systems, maybe another updates to grid codes, others may address an issue or add new features. There is a changelog in the professional area which should give you a good idea of the types of changes and whether it is actually necessary for you to upgrade. I'd suspect there would be reactive updates for issues and roadmap based ones, but this is only my view.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
30 People are following this question.
