muhamad avatar image
muhamad asked
where can i find "dedicated ignore ac input" in the assistants?
because i need to add safety off to the system, untill now i used dedicated ignore ac input in the virtual switch, in order to use the assistants i need to select don't use VS.
I need to use the same action but in the asssistants.
thanks.
Assistants
Alexandra avatar image
Alexandra answered ·
@muhamad
https://www.victronenergy.com/live/assistants:ignore_ac_input_using_the_generator_assistant
You can set it up almost with the same parameters as the Virtual Switch.
muhamad answered ·
@Alexandra
I don't have AC coupling in my system therefore it is not neccesary to do "grid converter support" assistant?
I just need to use "dedicated ignore ac input " using the assistants.
because i need to use another assistant, i must use the assistants and not the virtual switch.
need to choose the two first sections as you see in the picture below?
thanks.
southsideph avatar image
southsideph answered ·
Dedicated Ignore AC is on the virtual switch settings, enable VS and you will get the option. You do not need assistants if that is all you wantveconfig.png
