chris-saunders avatar image
chris-saunders asked
Shore Power - 30A & 50A - How to?
I am in the process of refitting SV ZoZo, a CT54. I am in the process of designing the new shore power connections and wanted some advice. I intend to have a single 240/50A shore power inlet on the boat which, with adaptors, can be hooked up to either 120v, 30A or 240v, 50A. I have a victron Isolation autotransformer (3600W) which will work fine for 120v 30A or 240v 15A giving me 240v out at approx. 13-14A. However, if I plug into 240v 50A I assume that the isolation transformer will not provide more than the 13-14A. Firstly, will I damage the isolation transformer if it is connected to a 50A supply or will it only draw 15A? Secondly, if this will limit the current I can draw from the shore supply I would like to add a 3P rotary selector switch to the supply before the isolation transformer to bypass the transformer and route the earth through a galvanic isolator to my Quattro (24/5000/240). If the selector switch output goes to the quattro then the supply will go across the isolation transformers output. Will this damage the transformer? Any better solutions?
Isolation Tranformer
The transformer will not actively limit the current.
It is rated for the current mentioned in the datasheet and if you pull more current it will damage/destroy the transformer.
So you have to add a fuse/breaker rated to the current of the transformer before it to prevent that.
chris-saunders answered ·
Thank you for your reply. So, if I connect the rotary switch after the isolation transformer then presumably only a minimal current will pass through the transformer (no load current) if a 240v 50A supply is connected to the input with switch position 2 selected?
The shore power input feeds the isolation transformer and the rotary switch via a 60A RCD breaker. Only when position 1 of the isolation transformer is selected will any significant curent pass though it.zozo-ac-source-schematic-11.jpg
