llowalong-farm avatar image
llowalong-farm asked
Multiplus2 GX startup
Hi
We have just installed our MP2 GX inverter. Switching on we get the Victron welcome. Then Status Invert then ACdisconnected +6w. The AC1 is connected via a sub board with CB to a power outlet. Is there something we have not done to get the AC flowing.
Thanks in advance
multiple inverters
@Llowalong Farm
Do you have a battery connected? Does it power up from the battery alone?
Has it been programmed at all? The base program is Virtual switch which has an ac ignore bias.
llowalong-farm avatar image llowalong-farm Alexandra ♦ commented ·
Thanks Alexandra
Yes inverter connected to 48v battery bank. Input power supplied thru Victron 150/70 solar controller
llowalong-farm answered ·
Haven’t programmed it at all.
Rob
Program your battery specifics before connecting to charger sources. Or in the case of the mppt program that
knownot avatar image
knownot answered ·
AC disconnected means ac input - not sure if that was clear.
