ro0ke avatar image
ro0ke asked
Could I have an expert opinion on controller size, if I’m going overkill or not?
Hi, just a quick go through with everyone so everyone knows how I got to where I did.
My plan is 6x 300watt panels totalling 1800watt of panels. The Voc for each panel is a touch under 35v and the Imp for each panel is a touch under 12A.
I’m thinking 3 panels in series for a total of 105v+25%
And each 3 panel array paralleled for a total of 24A + 20%
Do these numbers look correct to you guys?
Also controller I’m thinking the 150/85 is this appropriately sized or could I get away with a smaller one? I’ve seen the max wattage from the panels one of these could take is 2400W with a 24v system. All this with a 304AH 24v battery for the time being untill I get another 2 for total 608A.
Any opinions on this specifically the controller or could anybody point out where I’ve gone wrong, would be massively appreciated,
Thanks in advance
system design
Alexandra avatar image
Alexandra answered ·
@Ro0ke
150V is the right models range there for the VOC calculated.
1800÷24V is 75A so the closest model is the 150/85 there without loosing PV max power. So two thumbs up.
You could use a 150/70 if the price difference is worth it for you, but you would loose the other 5A at lower battery voltages.
ro0ke avatar image ro0ke commented ·
Thank you for the reply, really appreciate it
