macca avatar image
macca asked
Vehicle Bc/Dc 20amp charger feeding Victron Dc/Dc 12/12-30 charger in Caravan
Hi ,
I have a question and would like some recommendations?
I have just purchased a caravan which has a Victron DC/DC 12/12-30 non-isolated charger installed feed 2 Lithium batteries. My tow vehicle is a Toyota 200 series which has a Redarc BC/DC 1220 charger installed charging and isolating my auxiliary battery from my start battery.
My auxiliary battery feeds power to an Engel socket in the rear of vehicle and to an Anderson plug which feeds into the DC/DC12-30 victron charging the 2 lithium batteries.
Is having 2 DC/DC chargers on the auxillary system OK?? 1 - Redarc feed the auxillary battery and then the auxillay battery then feeding the Victron Charger?
Hope I’ve explained this clearly
orion dc-dc
kevgermany avatar image
kevgermany answered ·
Should work, but you may lose too much voltage over the cables/connectors to the caravan. Also the redarc will not keep up with the Orion, so the Orion will take charge from the aux battery in the Toyota.
Might work better if you swap the positions of the redarc and Orion. Or wire the Orion to the alternator direct, but make sure you're not overloading the alternator. You probably need a minimum of 100A to avoid alternator burn out.
