hello i have bought a Multiplus 1600 VA and the leds are always off
there is a correct entry voltage but no AC voltage and no green led on
the fuse seems to be ok
yes of course 2 12V batteries and a victron mmpt with float led on
If the multi has 12 (24?)v at its input terminals, and is switched on, it should work / green led.
Disconnect any thing plugged into the VE bus ports.
the fuse inside the victron ? there are no voltage when the swith is on
No voltage either side of the fuse??
You seem to have a bad connection between the battery and multiplus.
0v each side seems to be a problem before the fuse.
Check your wiring between the battery and inverter, on both neg and pos wiring.
Is the MultiPlus switched to ON, not charger-only?
DC voltage is at the battery terminals of the MultiPlus?
leds are off with or without panels
the victronconnect app and voltmeter mesure show 27.4 V at the DC entry of the Multiplus
Is the Multi switched to ON in the app?
What other components do you have?
i don't have VE bus smart dongle
i have no voltage in the inside fuse when switch is on, does it mean tht fuse is KO even if it seem clean ?
25 People are following this question.
