twase avatar image
twase asked
running a Compressor from battery feed to victron multi plus
I have a Victron easy solar 24V 3000VA I am installing in my caravan. It is supplied by 3 parallel 12v LiFEPo4 135aH batteries in series with the another identical 3 parallel 12v IiFePo4 batteries giving 24V battery.
I also have a 24v compressor for the air bags that I want to feed from the battery terminals on the victron. I have a ferrite filter in the feed to the compressor but not sure on its capability.
My Question is: is there any issues in this configuration with regard to the victron easy solar?
victron community
twase avatar image
twase answered ·
I Guess the question is how susceptable is the victron to external noise on the battery feed?
netrange avatar image
netrange answered ·
When the compressor starts up, the voltage must not fall below the "switch-off voltage" of the Easy. However, a short warning would be possible ...
twase avatar image twase commented ·
OK, I doubt any chance of the voltage dropping much, there is an inline 80A fuse, it has around 30A inrush and 17A running, I am more concerned about any back emf from the motor.
