keegs avatar image
keegs asked
Like to run air conditioner off my batteries as well as shore power and generator.
a2ef6c70-4952-4851-a339-68ddae175639.jpeg99d0cc8a-2211-45e0-9505-836f9cfa55f0.jpegImage Caption
setup
3 comments to make.
You have not provided any details of your system.
The photo of your distribution board shows major flaws.
Who built this disaster?
Contact the electrical safety board in your state and report this.
Paul B avatar image
Paul B answered ·
just move the ac2 connections from AC2 out and add them to the ac1 out connections, this means everything will then go through the inverter inverting side - if the inverter is NOT big enough it will overload and thus turn off. so you will have to limit what you turn on yourself -
Yes the main control panel does not look correct so you should get this sorted out as well.
