I want to know what are three relays on the Quattro 10KVA - 140A version . I have identified K1 and K2 as 2 relays but can anyone tell me which one is the third one since the manual says 3 relays are available that can be programmed to any logic.
Should be in the top right corner of the PCB. The "primary programmable relay" or VS (virtual switch.
In the manual appendix A the I.
thanks I found it in the manual but it doesnt say whether it is programmable too as the case for K1 and K2 . also if this is the primary one then can I select it inside Veconfig assistant to trigger external relay based on some condition of battery ?
I not H
25 People are following this question.
