fernando-mier-hicks avatar image
fernando-mier-hicks asked
Connecting 4x SmartShunts to microcontroller
What is the lowest mass/volume way to "bus" 4x SmartShunt Ve.Direct ports onto a single communication bus (Ve.CAN or VE.BUS) to then interface to a microcontroller?
  • Use 4x "VE.Direct to VE.CAN interface" cables https://www.victronenergy.com/accessories/ve-direct-to-ve-can-interface
  • Use 1x Octo Gx
Would 4x "Lynx Shunt VE.Can" be a better approach?
SmartShuntlynx shunt
wkirby avatar image
wkirby answered ·
It's not completely clear what you want to achieve here.
When you say microcontroller, what do you mean? Are you referring to a CCGX, CerboGX, OctoGX? Or do you mean mictrocontroller like ST, Microchip or Espressif?
What do you need to measure with the four SmartShunt? Battery current or load current.
fernando-mier-hicks avatar image fernando-mier-hicks commented ·
By microcontroller I mean a ST, Microchip, Arduino etc. I would add an appropriate CAN transceiver to the TTL-UART on the microcontroller to make it compatible with VE.CAN.
I would like to acquire as much data from the SmartShunt as possible: battery current, estimated SOC, temperature, battery voltage etc. The most important being estimated SOC.
steffen-graap avatar image
steffen-graap answered ·
The ve.direct is RS232. The easiest way would be to just hang the SmartShunts directly on the 4 UART port of the microcontroller.
