rv-masters avatar image
rv-masters asked
DMC not controlling MultiPlus II 12/3000 with Cerbo GX, Gx Touch 50
My DMC will not switch the MultiPlus II into on or charger mode. I can get the DMC to function by disconnecting it, switching the MultiPlus II to on with the GX Touch 50, and then reconnecting the DMC while the switch is in the on position. But as soon as I switch it to off, it will not turn the system back on or go into charger mode. Any thoughts?
Digital Multi Control
Where did you connect the DMC? Directly to the MultiPlus or to the Cerbo GX?
rv-masters avatar image rv-masters commented ·
The DMC is connected into the VE.Bus BMS (remote port) and the VE.Bus BMS is connected to the MultPlus II. The Cerbo is also connected directly into the MultiPlus II.
