johnny-brusevold avatar image
Raspberry Pi 4 version 1.4 images
Since there is currently no support for rpi 4 v 1.4 I post the latest original venus-os images with kernel v. 5.10.95-v7l+ and a folder with all overlay files from this kernel compile
EDIT
Updated with venus-os image for Pi-4b-V1.4
venus-image-raspberrypi4v1.4-v2.82_5.rootfs.img.gz
venus-image-raspberrypi4v1.4-v2.82-5-Lage.rootfs.img.gz
Google Disk
Venus OS
7 comments
Hello, thanks for the great work!
Is there a way to change this VenusOS image to SSD boot?
If so, what would I have to change for it?
Or can you make a changed SSD-boot Image without using a sdcard ?
Thank you ..
@Hundefreund02
It is certainly possible, but it involves possible change of firmware and some manual configuration. I do not think it has anything to do with venus-os image, except that perhaps some required tools are missing.
I also do not see the necessity of this with venus-os
Hi Johnny,
Is it possible to get a copy of your files 2.82, please?
Unfortunately, I own RPi4 v1.4 and official Venus os doesn`t work on it.
I've tried those new 2.90 on your disk, but it stops booting at the beginning (after 4raspberries image on the screen).
I really appreciate any help you can provide.
igorvanlife avatar image igorvanlife igorvanlife ·
Unless someone else have a copy of working Venus os on RPi 4 1.4 and could share.
Cheers ;)
@IgorVanlife
Looks like I've cleaned up a little too much.
v2.90-8 image boot fine on all my 1.5 boards, but have not tested them on v1.4 boards, so it is probably a change in the latest kernel or u-boot.
Found a 2.82-30 large image and restored it to google disk.
igorvanlife avatar image igorvanlife johnny-brusevold ·
Thank you for the fast reply!
It is my second day playing with RPI and I see it will be the hard one ;)
I`m still struggling to have it running. After start, I get root@raspberrypi4:~# command and that's all. So now I need to dig and learn as can`t go any further...
@IgorVanlife
You can connect to venus-os with your browser if you use wired network
http: //venus.local/
You will not get anything else on the screen that is connected to pi if you do not delete the headless file first and reboot
rm /etc/venus/headless
to create the hedless file again
touch /etc/venus/headless
If you use a wireless network, you need to configure the wifi network with the phone victron-connect app.
hundefreund02 avatar image
hundefreund02 answered ·
Thank you ..
on normal pi os, a clone for sd to ssd is enough to work.
on venos os i never tried, because venus is using most of time readonly, it doesn't destroy sd card fast.
matteburk avatar image
matteburk answered ·
Hi...@johnny-brusevold Newbie here. Just got a RPI 4 8G and trying Venus OS ......(the only one available in Sweden now).
Found out that there is no official Venus OS for that now but came across this thread.
I have burnt the image on my sd card and gets this on my screen....
Should I do anything more?
/Mattias
