I have recently bought and installed a IP22 Blue Smart charger and wonder whether its default settings are OK for sealed lead acid batteries. If so please advise whether I need to choose NORMAL or HIGH MODE. Thanks Mike
Hi @mikevictron,
default means 14.4V absorption voltage. That's a good value for AGM (another type of sealed lead acid batteries) batteries. A'normal' sealed lead acid probably will need a bit more juice, typically in the range of 14.6V to 14.8V.
I recommend to ask your battery supplier or check the data sheet for the battery and verify that 14.4V is ok.
26 People are following this question.
IP22 and MPPT 75/15 Stop Charging Due to Low Temp
Blue smart charger Functionality Device/App
How to disable Storage mode in IP22 Bluesmart chargers?
Amazon was the seller for an IP22, and I bought a warehouse deal, is warrantee still good?
Parallel use of Blue Smart IP22, MPPT 100 /20 and DC2DC 12|12|18 on the same bus with load?
