jejochen avatar image
jejochen asked
possibel to use 2 systems on 1 grid meter ?
I want to combine a wallbox pro ev charger wich has smart charging functionalities with an ESS system. (EM340 in this case).
Can i connect the 2 upt wires on 1 meter, or will this cause malfunctions? (don't know if this is potential free).
If not, it will be a 2nd em340 to be installed i guess.
ESSEnergy Meter
jejochen answered ·
Did the test with metering the cerbo at the usb cable wires, and it gives 5V. So a 2nd meter is necessary.
