this loading device has afaik 3 Outputs with 30A max. each. Is it possible to use two outputs from this device in parallel on one battery to increase charge current? E.g. to load a 200AH LiFePo4 Battery with 60A.
kind regards
itchako
kind regards
itchako
Whilst you can parallel the outputs from one device, you won't get any more current as the TOTAL current delivered is limited to 30A. If you need more current, then use 2 chargers in parallel.
24 People are following this question.
IP22 and MPPT 75/15 Stop Charging Due to Low Temp
Blue Smart Charger - Supply mode using Smartshunt or bmv-712 capacity values
How to disable Storage mode in IP22 Bluesmart chargers?
Amazon was the seller for an IP22, and I bought a warehouse deal, is warrantee still good?
Parallel use of Blue Smart IP22, MPPT 100 /20 and DC2DC 12|12|18 on the same bus with load?
