boeta avatar image
boeta asked
Advice for bush trailer DC charge system
I am planning to upgrade my dual battery charging system in my trailer, using a Orion, MPPT, IP65 AC DC and the BMV712 smart shunt units. However I am not sure if my setup as in the attachment is correct and I will appreciate any comments on this setup please.
Charging system for dual battery setup.pdf
system design
kevgermany avatar image
kevgermany answered ·
Looks similar to mine. Should be good. But isolators/fuses on the battery would be good.
boeta avatar image
boeta answered ·
Thank you for the comment, I completed the installation, only one problem is that the BMV unit does not measure the correct voltage of the starter battery, it only measure 0.72 V instead of 13V. I am not sure why.
Do you have a good negative connection between the starter battery and the load side of the shunt?
boeta avatar image
boeta answered ·
Thank you for the advice.
The negative of my starter battery does not connect directly to the load side of the shunt, the (-) from the starter battery is wired to the (- Input) of the Orion and the (- output) of the Orion connects to the load side of the shunt.
That's probably the problem. But the negatives on the Orion are common, I think.
But they're probably not not on the isolated ones. Will check tomorrow
kevgermany avatar image kevgermany ♦♦ kevgermany ♦♦ commented ·
Checked. Negatives are not joined, but are isolated on the isolated Orions. At least mine is like that.
boeta avatar image boeta kevgermany ♦♦ commented ·
Thank you for your help!
