david-delorme avatar image
david-delorme asked
BSC ip22 absorption voltage to high
I have BSc ip22 and a bmv 712 smart. The network is working. The issue is the absorption voltage as reported by the BMV is 14.57 and today it was 13.67. if I go onto the charger and select any other profile and then click back to normal. It drops back down to 14.40 volts at the battery. I understand that the charger voltage is higher to maintain proper battery voltage. I have about 2.5 % at 30 amps measured. Is this a bug in the software or is it a communication issue at startup.
bluesmart ip22
david-delorme answered ·
Sorry but I ment 14.67v not 13
