I'm planning to install a green energy bank, either 2 solar panels & a wind turbine or doubled up on my 53' sailing boat that has shore power, inverter, 6kva generator & 4*220Ah AGM consumer batteries bank (24v, 18 months old,) and Victron Skylla-TG 24 50 Battery Charger. Max output from the Bank could be either 500w or 1kw. I've noted Genny output of 20 amps (reducing) with the water heater switched on.
Is is possible to get a Controller such that the 'green energy' is transformed up to 220v and used to supplement the shore power feeding the Victron Skylla Controller as opposed having to run off the Inverter? I'm also intending to sail across the Atlantic to Canada & USA.
