re18 avatar image
re18 asked
Connect ruuvi to CCGX or Venus GX
Hi Victron Community
I‘m using a CCGX and I like to add some Ruuvi Temperature sensors. Since the CCGX has no bluetooth I‘m wondering, if it is possible to add them via adding a bluetooth dongle?
CCGX Color ControlVenus GX - VGXBluetoothruuvi sensors
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ commented ·
Hey @RE18 , hope you don’t mind your question getting used to become the central point for everyone around using a ruuvi on a CCGX or Venus GX. I’ve slightly edited your question to prevent confusion - hope thats ok.
re18 avatar image re18 mvader (Victron Energy) ♦♦ commented ·
Perfect, thank you.
Hi all,
In this post, I have listed all dongles tested by Victron, as well as others.
Generally speaking, any USB Bluetooth dongle featuring Bluetooth 4.0 will (most likely) work on GX device.
The main purpose of this list is to guide which USB Bluetooth dongle buy and use to get wireless temperature monitoring using the Ruuvi wireless temperature sensors. To use mainly on a CCGX, Venus GX, and also the Cerbo GX. Why the Cerbo GX? Thats because even though the Cerbo GX features built-in bluetooth, that doesn't work reliably enough. More details about that on in the GX product range datasheet.
For now we won't be stocking them ourselves, since that will only make them rather expensive for anyone to buy; whilst freely available on the internet for just a few USD up to 10 or 20 USD, without ourselves, and our dealer network, to be in the middle.
List of tested dongles by Victron, that work:
  • Logilink BT0037
  • TP-Link UB400(UN)
  • Ewent EW1085R4
  • Laird BT820
  • Laird BT851
  • ASUS USB-BT500
All above list was tested from -17 to 70C.
List of tested dongles that don't work:
  • TP-Link UB500(UN)
  • Avantree BTDG-45 (Avantree DG45)
  • Nobrand 5.0 USB dongle (amazon link)
List of dongles tested by others that work:
  • Insignia (NS-PCY5BMA2) for $14.99, tested by @Roamer105 , see below.
  • Kinivo BTD-400 - tested by @Al , see below
  • Ideapro USB bluetooth adapter 4.0 - tested by see below
And some comments on what doesn't work: several Bluetooth 5 dongles that we tested do not work. Most or even all Bluetooth 4, or 4.2, did work. Reasons for them not working differed per unit. Some might benefit from a newer kernel, or newer library of linux-included firmware files. But our aim was just to test what works and what not, so we stopped there, and did not, and are not aiming to in the near future either, spent time on making them work.
Whilst finding a compatible WiFi dongle can be difficult, Bluetooth is -luckily- different.
More tests welcome!
If you tried another one, and it works, please let everyone know by posting here - thanks!
Victron VE.Direct Bluetooth Dongle won’t work for this
The Victron VE.direct Bluetooth dongle is not designed to connect to a CCGX or Venus GX, it is only for devices like MPPT, Phoenix inverter or BMV-700/702.
What does Bluetooth add?
Bluetooth on a GX Device currently servers two purposes:
1) you can configure the ethernet and wifi networking, using the VictronConnect app.
2) you can read temperature and humidity from the Ruuvi wireless sensors (requires Venus OS v2.80 or later).
17 comments
ps. I ordered four dongles on Amazon, which we'll test ourselves and confirm here if they work or not.
  • TP Link UB400, Amazon ASIN B07NQ5YGDW, EUR 9,50
  • Macly Bluetooth 5.0 USB, Amazon ASIN B08FH88MBX, EUR 6,99
  • Avantree ‎BTDG-45-BLK, Amazon ASIN B08GM1MV6B, EUR 14,99
  • TP Link UB500, Amazon ASIN B098K3H92Z , EUR 14,50
The Amazon ASIN number is the unique reference to an item on Amazon. Note that I took those ASINs from www.amazon.nl, and they are probably listed under a different ASIN on the other Amazon markets/websites.
joe-d avatar image joe-d mvader (Victron Energy) ♦♦ commented ·
Thank you...let us know which ones worked for the Venus GX. I assume all that you have to do is plug it in and the GX USB slot and it automatically recognizes it along with the Ruuvi sensors? Also, I have a GPS antenna plugged into the USB next to the microSD card slot so I assume I can use the USB next to the Ethernet port (on the other side)?
Joe
philippe avatar image philippe mvader (Victron Energy) ♦♦ commented ·
@mvader (Victron Energy) Hi, I installed the TPLink UB500 on the Venus GX (v2.80~36) and have a couple of Ruuvi laying arround. The parameters on the menu, Bluetooth and the IO/Bluetooth sensor appears but no devices. When I dig into the OS, It seems that the scan does not work.
Bluetooth Monitor >> Status: Command Disallowed (0x0c)
Bluetoothctl >> [bluetooth]# scan on Failed to start discovery: org.bluez.Error.InProgress
Seems that another process/service is already running or cause a conflict. Hope you have some ideas what is going wrong :D
Happy 2022. Best regards, Philippe
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ philippe commented ·
Hi phillippe thanks, we tested the same. doesn't work.
@mvader (Victron Energy) Hi Matthijs. I assume we are in the linux built 5.10 and this will not change quickly??
So apparently in the btusb.c the next entry is missing. https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1948502
/* Tp-Link UB500 */
{ USB_DEVICE(0x2357, 0x0604), .driver_info = BTUSB_REALTEK }
it will be solved in a futur release, or it can be added and compile the kernel.
https://askubuntu.com/questions/1370663/bluetooth-scan-doesnt-detect-any-device-on-ubuntu-21-10/1371453#1371453
Hope you can do something with this information.
Hi, we are at 5.10 and indeed I don’t see a need to go spend resources on fixes like this.
Why not get a dongle that is tested to do work instead?
changing that will mean also testing again that nothing breaks, etc etc.
same for ant other dongles that don’t work - no matter the reason: we will not spend time on making them work; however trivial.
That bluetooth works on a CCGX and Venus GX is already unexpectedly nice, and there are enough dongles that do work without requiring work.
Sorry to be firm on this, but to make progress, we need focus.
Totally understood. Just I was faster then the tread to buy the dongle and the ruuvi's. Did spot only later on the fact that it is normally only supported on the Cerbo and not on the Venus/CCGX, but another 400€ to buy a Cerbo, is just over it. I have only the Venus for 2 years. But thanks for coming back with the details.
I installed the ideapro USB Bluetooth Adapter 4.0 on my Venus GX and it seems to work. I do not see the temp on the Remote Console but I can see the sensor on VRM-Advanced (with temp widget selected) .
I noticed that the GX relays will not use the bluetooth temperature sensors? Will that be fixed?
Also, will there be a way to rename the sensor? Right now I see Ruuvi XXXX (XXXX is serial number) on the Remote Console (Settings->I/O->Bluetooth sensors) but in VRM-Advanced it shows up as Temperature [25]. Its tough to keep track with many sensors.
joe-d avatar image joe-d joe-d commented ·
Digging into this further, the Ruuvi does show up on the main screen of the GX Remote Console and can be setup as "Battery", "Fridge: or "Generic" types (this "type" does not seem translate to VRM Advanced display, still shows Temperature [25]), but the Dashboard of VRM does show the Ruuvi information and "type"
Also can setup bluetooth sensor for relay operation.....still confused on how to setup a single relay that can be controlled by multiple sensors and what is Condition 1 and Conditon 2? Is this explained somewhere?
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ joe-d commented ·
Hi, I’ll add that dongle to the list. Thank you!
Setting a custom name (Device list -> My sensor -> Device submenu) works for me. Also on VRM advanced page. We’ll check the rest. For further discussion, pls start a new thread - or post an answer to the beta thread, since ruuvi is still beta.
Dont use this one, I’d like to keep it clean and for dongle compatibility only, thank you!
Yes, this worked for me as well to rename Ruuvi. THX
Understand to keep this thread clean.
Hi all, an update, I added various dongles that do work (we tested them here in the office) to above list. And also listed a few that don't. see above.
pdonner avatar image pdonner commented ·
I've ordered a couple of TP-Link UB400 dongles and they do offer Ruuvi compatibility for CCGX units. It is, however, unclear what procedure should be followed in order to disable the built-in bluetooth functionality on a Cerbo.
Would anybody be able to indicate the procedure to be followed when the built-in device is being replaced by the dongle, as recommended?
pdonner avatar image pdonner pdonner commented ·
The internal bluetooth functionality is disabled as usual in the menu structure: Device list > Settings > Bluetooth > Enable <Off>. After this the inserted USB dongle takes over.
As the dongle bluetooth interface isn't visible in the menu structure there isn't a way of setting the pin code as a filter (and to provide additional security). This could be an additional risk in a setting where temperature readings are used to control relay functionality.
Perhaps the usb enabled bluetooth dongle parameters (enable, pin) could be made visible in the future?
Warwick Bruce Chapman avatar image Warwick Bruce Chapman pdonner commented ·
I second this.
chris-john avatar image chris-john commented ·
I’ve got 3 Ruvvi sensors on my narrowboat and the one furthest away from Cerbo keeps dropping out. Plugged in one of the recommended Bluetooth dongles. Then what do I do?
chris-john avatar image chris-john chris-john commented ·
Doh I’ve worked it out. Turn off the Bluetooth in settings and the dongle takes over. Not sure it’s good for security though but Ruvvi working fine now
ejrossouw avatar image
ejrossouw answered ·
I was waiting for this ;) The VenusOS is on all the GX devices so from that point of view, it should be ok, but the fuctionality will only be available next year. However, getting bluetooth fuctionality on the Venus or CCGX using a bluetooth dongle, I do not actually have the answer given I have never seen anybody actually use it like that.
Venus OS is running on all GX devices but only the Cerbo GX has Bluetooth.
The VE.direct Bluetooth dongle is not designed to connect to a CCGX or Venus GX, it is only for devices like MPPT, Phoenix inverter or BMV-700/702.
https://www.victronenergy.com/media/pg/VE.Direct_Bluetooth_Smart_dongle_manual/en/introduction.html#UUID-b9ae5428-910d-2666-2ca7-7f430615d80c
https://www.victronenergy.com/media/pg/VictronConnect_Manual/en/compatible-victron-products.html
roamer105 avatar image
roamer105 answered ·
I installed 4 Ruuvi sensors. They are great and quite accurate. I use a CCGX running the latest beta firmware. Since between the Tank 150 and GPS receiver the two USB connectors are both used. I simply added a small hub, moved the Tank 150 to the hub along with an Insignia Bluetooth adapter from Best Buy.
Without even restarting the CCGX it showed Bluetooth active and found all of the Ruuvi devices. No issues.
Thanks!
5 comments
harold avatar image harold commented ·
Did you buy this from the USA?
roamer105 avatar image roamer105 harold commented ·
I live in the USA. The recommended Bluetooth adapter in this thread is not available in the USA. So I got an Insignia (NS-PCY5BMA2) version of it for $14.99.
The Ruuvi sensors came from the factory via DHL. No issues, no extra cost.
Stuart Bell avatar image Stuart Bell commented ·
Hi @Roamer105 . Could you explain what needs to be done on the CCGX once the Bluetooth dongle is connected to "connect" to the Ruuvi? I'm running VenusOS 2.80-36 on the CCGX.
Thanks
roamer105 avatar image roamer105 Stuart Bell commented ·
Go to settings - I/O - Bluetooth sensors and click enable. It will show the sensors it finds. Enable them too
They will appear in the device list where you can change the name etc.
Stuart Bell avatar image Stuart Bell roamer105 commented ·
Thanks - much appreciated
Al avatar image
Al answered ·
I've just ordered 4 Ruuvi tags, some active USB extension cables and took a punt on a dongle:
Kinivo BTD-400 Bluetooth 4.0 USB Adapter (Low Energy Wireless Dongle) - Windows 10 / 8.1 / 8 / 7 / Vista , Raspberry Pi , Linux , Mac (2011 & beyond) and Stereo Headset Compatible by BlueRigger LLC
https://www.amazon.co.uk/dp/B007Q45EF4/ref=cm_sw_em_r_mt_dp_MGG6XE7V4PVTR4NAEV1H_encoding=UTF8&psc=1
I saw lots of similar dongles but many explicitly state they don't work on linux or Mac, I'm assuming we need dongles that will work with native linux drivers to talk with VenusOS? Which is why this one looked good.
I'll update when they all arrive late next week hopefully, and see if they play with the CCGX.
I also saw quite a few Bluetooth 5 dongles with aerials for 100m range, it would be interesting to see if any of these worked too!?
https://www.amazon.co.uk/dp/B09HJV51FR/ref=cm_sw_em_r_mt_dp_dl_J3A8344H552X7JSN0CZQ?_encoding=UTF8&psc=1
8 comments
Al avatar image Al commented ·
*Update. Ruvvi Tags arrived to the UK customs paid today (Ordered Friday night, arrived Tuesday Morning) , and I can confirm the Kinivo BTD-400 I ordered from Amazon link above, works plug and play in the CCGX. I did use the Ruuvi android app to update Ruuvi firmware first, but the Kinivo BT dongle I just plugged in to the CCGX and turned on bluetooth, currently running Venus OS v2.80-36, all populated happily.
Just a quick test and I found they connect happily at 17m distance indoors line of sight.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ Al commented ·
great! added to the list above, thank you.
mje avatar image mje Al commented ·
Um - how did the info appear on your (front) screen? I can see the RUUVI, I can see its details, it shows in VRM - but nothing on the "front page" of the screen (at the bottom, like your example). I'm obviously missing something. This is all on a Cerbo GX, latest software (2.80~36) - etc. Also how does one remove a Ruuvi Sensor? It's no longer on my Cerbo GX - but still on VRM!!!
harold avatar image harold mje commented ·
It look like @Al is running OS Large on a CCGX ?
I didn't know it could ?!
Al avatar image Al mje commented ·
Hi @mje I haven't tried myself but I think you should be able to delete from VRM, but there was a thing about hanging sensors in v2.80~36.. not sure if that's relevant.
I installed GuiMods which adds a few extra features to the flow overview display to see the temps: https://community.victronenergy.com/idea/77971/venus-os-modification-scripts.html
Thanks - deleted from VRM.
I'm adding your scripts to my Cerbo!
Waiting for more Ruuvi to arrive before I test.
alan avatar image alan Al commented ·
What sort of range are yo getting with that, I need something that will do approx 15m. Through cold room wall.
Al avatar image Al alan commented ·
Hi @Alan 15m for Ruuvi to GX should be fine, but it depends on what the cold room wall is made of? The usb extenders seemed to work well if you need them, but I swapped the USB cable for an AV Access USB extender over CAT as I was and still have regular CCGX reboots, but I think that's more a limitation with the CCGX processor or GuiMods, either way the reboots are not a big deal, and both ways of extending if necessary should be fine especially if you have a Cerbo / rpi. The AV Access extender: https://www.amazon.co.uk/dp/B01EV33R8S?ref_=cm_sw_r_cp_ud_dp_GBR039GDN7Y3BZYB27TK
brezzi avatar image
brezzi answered ·
Will the data of the ruuvi sensor be avalible in NodeRed?
hi @brezzi , yes it will. Might take a little while (weeks), but it will. And welcome to community!
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ mvader (Victron Energy) ♦♦ commented ·
ps, for further discussion on node-red, please use the Modifications section on Community.
@Al - I got one of the long range bluetooth USB dongles from Amazon -
https://www.amazon.com.au/gp/product/B08LVH5BCP/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
It immediately connects, no issues so far, and I can see all the Ruuvi sensors on my property (some 20M+ away through a steel shed).
I will leave it connected and see how it goes for a while.
16 comments
Thanks Guy, that's good to know and interesting as it seemed quite a few of the Bluetooth 5 dongles tested above didn't work.
Tom avatar image Tom commented ·
Hi @Guy Stewart (Victron Community Manager) .
This long range dongle is not currently available. Any other suggestions?
Where are the steps to add Ruuvitag info to the GX Touch? Thank you!!
randy-s avatar image randy-s Tom commented ·
Hi Guy, very interested in this solution. It seems to be available here in Amazon Canada, but it specifically states it does not support Linux (and Mac OS etc). So should I be ok to go ahead and order it? Or is it maybe something unusual that it did work for you. Thanks.
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) ♦♦ randy-s commented ·
There is nothing special that I am doing, so I think it will work just the same for you.
You would be another one of only a few data points, so taking a little chance that it might not work.
Amazon is usually pretty good at returns if necessary.
That is actually a slightly different one I believe. It is BT 5.1. The one Guy suggested is BT 5.0. I don‘t know what if anything the difference is. Mine just arrived today, I’ll report back as soon as I get it installed.
houlster avatar image houlster randy-s commented ·
Can comfirm that the ZEXMTE long-range BT 5.1 version works as well. It's only been a couple days, but it showed up on the Cerbo / Touch display and connected to my Mopeka LPG sensors fine.
https://amazon.com/Bluetooth-Adapter-ZEXMTE-Windows-7-Bluetooth/dp/B09MZ8715D
randy-s avatar image randy-s Guy Stewart (Victron Community Manager) ♦♦ commented ·
I got the BT dongle and not sure how to install it. I’ve done a lot of searching and reading and no joy. I plugged it into the USB port right beside the USB port the Touch 50 plugs into, rebooted the Cerbo, and I can’t find anything in the settings that shows this new dongle.
Any chance you could give me a quick walk-through of the steps required to get this up and running? Also, once successful, how would the Ruuvi tags (or even Victron Connect app on my iPad) know which BT to connect to - the original built-in BT or my newly added USB-BT device? Thanks.
mvader (Victron Energy) avatar image mvader (Victron Energy) ♦♦ randy-s commented ·
Hi @Randy S , the Ruuvi's don't need to connect to anything. They broadcast the information, and any bluetooth radio, aka dongle, can listen and retrieve the information.
Make sure your Cerbo is running the latest official version, which is v2.84.
And go to Settings -> I/O -> Bluetooth sensors. That is where you find the settings.
randy-s avatar image randy-s mvader (Victron Energy) ♦♦ commented ·
Thankyou for the reply. Sorry, perhaps I wasn’t clear. I have 3 Ruuvis. I can see all of them through the Ruuvi app on my iPhone/iPad. I can only see 2 of them on the Cerbo. The furthest away one does not show up. I read in several places including this thread that the BT radio was not very strong in the Cerbo and it was better to install a dongle. So I did….or tried to. I got the exact same one that Guy tried and was successful with. Being advertised as long-range was attractive due to the mounting location of my Cerbo and location of the last Ruuvi.
My question was about how to install the dongle. I did as per my description above, but I don’t know if there are some other steps. I do not see this dongle as an entity, and don’t know where- all to look. The various locations on the Cerbo look exactly as they did before. I can see the 4 hardwired temperature sensors and the same 2 Ruuvis as before. My concern is perhaps the new dongle is not working. How would I determine if it was correctly installed and working correctly. Thanks.
Hi @Randy S , that is a good point: at the moment it is not possible to see if the inserted dongle is working correctly. I'll think about how we can fix that in a future version.
If the dongle you're using is one in above list, then most likely it works.
Note that "long range" can mean many things (better antenna, but it can also refer to a Bluetooth Long Range specification, which I don't think the Ruuvi uses), and the signal strength will still be limited by the Ruuvi itself.
I recommend to use an extension cable and decrease the distance between the missing ruuvi and the bluetooth radio. 99% chance your issue a range problem.
I find this whole thing puzzling and perplexing - how can a device not know that something is connected to it?! However, I will make an observation - there is one Ruuvi that is in a freezer outside on the dock, about 25’ away from the Cerbo. It did not show up on the Cerbo by itself. However, about 15 minutes after plugging the BT dongle into the Cerbo, I did see it show up. Also required was some combination of re-booting the Cerbo and/or powering it off on on (pulling the fuse). I cannot be certain of cause/effect because there seemed to be a great deal of randomness to the whole process. So for now I’ve concluded the dongle must be working.
One other potentially significant observation; again not conclusive because of the apparent randomness of cause and effect. But it appears that if the Bluetooth link between the iPhone/iPad app gets broken, there is no way to pair them again unless you remove the BT dongle and start from scratch (power down/up etc). While in this state there is no way to access Remote Console. That’s a major problem!
I must say this appears to be an extremely fragile and unreliable system. It seems to require randomly switching settings on and off until it works, and then it works until it doesn’t, again for often unknown reasons, and then once again just randomly “doing stuff” until it starts working again. It extrem frustrating and disappointing.
I would add though that the philosophy and conceptual design of the Victron components is outstanding. Brilliant. But execution of the concept and user interface and interaction is lacking.
Tom avatar image Tom Tom commented ·
Dave Rae avatar image Dave Rae commented ·
Hi all, just purchased a DIGITECH - XC4956 V4.0 Bluetooth USB dongle From Jaycar for my CCGX, its fully operational no problems at all.
Cheers..
alan avatar image alan commented ·
I purchased one of these for a CCGX and it doesn’t seem to work at all.
The ccgx seems to know that it’s a BT dongle as the I/O menu appears but that’s about the extent of it. It also causes the CCGX to lock up and reboot. The ruuvi tags were less than a meter from the dongle at that stage and not detected.
Does the led indicator on the dongle illuminate? I’m trying to ascertain if I just received a faulty one.
I tried it on my windows pc and it also doesn’t work there with error code 31 unable to start driver. Could you possibly test it for me on a windows pc.
Otherwise any other long range dongles recommended that work on the ccgx?
This would be so much easier if you just made the ruuvi gateway compatible on the venus os, via http/mqtt.
Not only would it then be extendable via a network to other buildings easier, it would probably have better bluetooth range due to the CP antenna on the gateway.
alan avatar image alan alan commented ·
Your assistance would be appreciated here
Daniele Calabrese avatar image
Daniele Calabrese answered ·
I did install 3 sensors in my 40 feet boat with the existing bluetooth sensor even if i bought the suggested tp-link usb dongle. here is the screen shotScreen Shot 2022-02-24 at 14.07.33.png
roberto-mazzucato avatar image roberto-mazzucato commented ·
Hi Daniele, i had a look on your attached photo, I’m setting it up my VRM system , but I’m not able to
display the ac input, yours seems runnnig very well, can you please give me some hints?
Thanks
pdonner answered ·
The main article of this topic comments upon the Cerbo GX bluetooth functionality: "Cerbo GX features built-in bluetooth, that doesn't work reliably enough." There is also a reference to the the GX product range datasheet, where the nature of the problem is explained in this way: "The Bluetooth function in the Cerbo GX stops working when the internal temperature is too high."
In order to evaluate usefulness of the built-in bluetooth functionality of the Cerbo, it would be helpful to hear the specifics of these limitations.
Hi @pdonner , perhaps outdated by now, but to answer your question: there is no need to do any investigation in the usefulness of the built-in bluetooth functionality of the Cerbo.
The conclusion is: do not use it. And use an adapter instead.
Its that black and white. Any middle ground / gray area will only lead to unreliable systems, and disappointment.
pdonner avatar image pdonner mvader (Victron Energy) ♦♦ commented ·
Thank you @mvader (Victron Energy) for sharing my concern of the Cerbo built-in bluetooth functionality. Refining Cerbo as a control center for home automation is a very appealing idea. On the other hand, Ruuvi is perhaps the only IoT related device in Finland with any mass distribution, which made me excited when development of this Cerbo extension took shape.
Despite all usefulness of Ruuvi in everyday use, it seems that we should be careful about making a system solely dependent on this bluetooth component.
However, we would like to construct a number of UPS systems with temparature control. Some of the Victron units arrive with built-in or external temperature devices. Can you point at the adapter that you recommend to combine with Cerbo which has a bunch overwhelming I/O capabilities (yet to be harnessed).
Dave Rae answered ·
Bluetooth dongle from Jaycar, DIGITECH XC-4956 v4.0 on the CCGX seems to function correctly.
cheers
randy-s avatar image randy-s commented ·
How do you know if it is fully functional Dave? As you can see from the response I received above from mvader, apparently there is no way to tell if it working correctly. I cannot even determined if it is installed.
Warwick Bruce Chapman answered ·
I want to add that we have tested the UB400 on a MultiPlus-II GX with a USB Hub (Digitus Slim Spider) and it works.
macca61 avatar image
macca61 answered ·
Hi i have just tried a Sabrent BT-UB40 from Amazon UK , it works , i can see both Freezers on VRM but cannot see them on my CCGX is there something in particular i have to do to see them please ?
Jeremy Albrecht avatar image
Jeremy Albrecht answered ·
Is it possible to connect any non-Ruuvi bluetooth sensors to Venus? have a number of sensors already in use from Govee and it would be nice to not have to replace all of them.
Hi @Jeremy Albrecht , no thats it not possible, sorry.
alan avatar image
alan answered ·
4 comments
I found one somewhere else for about half the amazon price, they also make a 5db dipole antenna (which I grabbed as well) and a 9db patch (which is rather pricy but could be great if longer range is required.)
will report back
Update: If anyone cares.
The Sena UD100 works perfectly with a CCGX and with the 5db dipole, range to the ruuvi tags is for lack of a better word, incredible.
shellness avatar image shellness alan commented ·
Can you advise whether the Sena was Plug-&-Play - this site says you have to load Bluez for Linux installations and this is beyond my competence?
To see my Ruuvis I have some metal walls to get through/around. If anyone has been successful with any long range adapters it would be good to hear - 99% of the ones I can find state incompatibility with Linux.
alan avatar image alan shellness commented ·
Hi, sorry for the late reply. This was plug and play with stock ccgx firware 2.89.
I had metal walls and it required a directional 14dbi 2.4ghz antenna (aliexpress)
alan avatar image
alan answered ·
Tried the Targus ACB75A from my pc on the rp3 running venus and it works.
randy-s answered ·
I’m always looking for “a better way”. My Cerbo install replaced my original Blue Power Control that had a BMV-702 feeding it. I also had the VE.Direct Bluetooth dongle to provide remote connection via VictronConnect. These are now no longer used. I have the BMV-702 connected to the Cerbo with VE.Direct cable.
Can I connect the VE.Direct Bluetooth dongle to the Cerbo and use it instead of a BT USB dongle? The connection range of the VE.Direct BT dongle is very good; much better I think than the USB dongle that I currently have plugged in.
Also, as per above discussion, there is currently very little support for a USB connected BT dongle eg the Cerbo cannot even tell it is connected. Would the Victron VE.Direct BT dongle have better support/features/usability?
Thx
randy-s answered ·
Anybody?
randy-s answered ·
Still looking for an answer; sorry if that wasn’t clear.
In short, can I use my VE.Direct Bluetooth Smart Dongle instead of a USB BT dongle for the purpose of communicating with my Ruuvi sensors?
Thanks.
Hi @Randy S
No, you can't use the VE.Direct Bluetooth Smart Dongle to connect a Ruuvi sensor to a Cerbo. The VE.Direct Bluetooth Smart Dongle can only be used on a so called VE.Direct producer (MPPT/BMV/SmartShunt/...) in combination with VictronConnect on a phone/tablet/macbook.
With kind regards,
Thiemo van Engelen
shellness answered ·
I am not clear on the specification requirements for the extender. This LM1010 unit offers Linux BlueZ support and Bluetooth 4.0 (dual mode) and operates in HCI mode:
  • Ubuntu 15.10 (Kernel 4.2.0-16-generic)
  • Ubuntu 14.04.03 (Kernel 3.13.0-77-generic)
Is there anything in the spec that says it can't work with the GX/Ruuvis? If not, the price is good and I am happy to experiment.
LM1010 USB Bluetooth Adapter.pdf
I used my build in bluetooth for months no problem now randomly bluetooth disppears from the list of devices in cerbo and then reappears. nothing changed in the boat same hot temperature hahah in thailand. any advice? shall I connect the usb tp link 4.0. I have it but I thought the ruuvie where bT LE 5.0
mje avatar image mje commented ·
My built-in bluetooth also stopped for lunch - and might come back early evening. I understand that there is a heating problem?
Anyway - added a USB Bluetooth 4.0 dongle (no name brand) and everything is now OK. I have 4 x RUUVI (Fridge/Freezer/Indoor/Outdoor) in my Caravan.
Recently added a "Mopeka EyeGasPro" on the bottom of my LPG cylinder - it's working fine. Mopeka also has very similar water device (Bluetooth & Sonar) - so ordering one to test with for my plastic water tank.
same problem here I added a bluetooth tp-link 4.0 as suggested the builtin bluetooth is gone nore sure why maybe 2.92 or 3.0 beta 4 I tried
rubicon avatar image
rubicon answered ·
Will the USA version of the TP-Link UB400 work with the Cerbo GX on an iPhone?
PeterM avatar image
PeterM answered ·
Tp-Link UB500 - In the beginning it was stated it does not work , but a bug has been found and it will be resolved. Can some confirm if indeed it has been resolved - thanks
Daniele Calabrese avatar image Daniele Calabrese commented ·
That would be food ad 5.0 wpild extend the range
Simo Hassi avatar image
Simo Hassi answered ·
I have a quite basic question. I'm trying to connect Ruuvi sensors to my CCGX. I have Installed a TP-Link UB400 bluetooth dongle and the CCGX recognises it but no Ruuvis detected. Firware is 2.93. I read that Venus OS should be at least 2.80 but I don't know how to update it. (I suppose that CCGX is running Venus OS, or is it not?)
Simo
4 comments
pwfarnell avatar image pwfarnell commented ·
The CCGX runs Venus OS so if the CCGX says it is V2.93 then it should be OK. Can you read the Ruuvitags on your phone using the Ruuvi app. Are there any walls or other things between the TP400 and the Ruuvitags that could block the signal.
Dirk-Jan Faber (Victron Energy) avatar image Dirk-Jan Faber (Victron Energy) ♦ commented ·
Just to be sure. You did enable Bluetooth under IO -> Bluetooth sensors? Just tested on a CCGX running 2.93 with a TP-Link UB400 bluetooth dongle and the Ruuvis and Mopeka show up without problems (at a few meters distance)
Simo Hassi avatar image Simo Hassi Dirk-Jan Faber (Victron Energy) ♦ commented ·
No, I have not seen those options on my CCGX. There is only Bluetooth (not sensors) and and on that page "Enabled" and "PIN code".
Simo Hassi avatar image Simo Hassi Simo Hassi commented ·
Now I got it! I was in the wrong setting. Thanks a lot!
Best wishes
Simo
OK, I was just confused when firmware is mostly called firmware but sometimes Venus OS. I didn't understand that they are the same thing.
Yes, Ruuvi app reads the sensors OK. I put one of the sensors at 20 cm distance to the CCGX where the bluetooth dongle is connected but with no success.
